Код:
Exposure: AWB Sharpness ++ Exposure: Lower 1/3 (this will help fix the dark ground problem) Meter mode: Foreground Dynamic range bias ++ (this will help fix the dark ground problem) Dynamic range limit +++++
Вот все хорошо, но “+” это сколько? Может сообразит кто… 😃
{"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"50063c2a3df955007774201c":{"_id":"50063c2a3df955007774201c","hid":122518,"name":"vasia","nick":"vasia","avatar_id":null,"css":""}},"settings":{"blogs_can_create":false,"blogs_mod_can_delete":false,"blogs_mod_can_hard_delete":false,"blogs_mod_can_add_infractions":false,"can_report_abuse":false,"can_vote":false,"can_see_ip":false,"blogs_edit_comments_max_time":30,"blogs_show_ignored":false,"blogs_reply_old_comment_threshold":30,"votes_add_max_time":168},"entry":{"_id":"509a0057997073007710982c","hid":15533,"title":"kx-201","html":"<p>Есть настройки для нее, Вова такие ставит:</p>\n<p>Код:<br>\nExposure: AWB Sharpness ++ Exposure: Lower 1/3 (this will help fix the dark ground problem) Meter mode: Foreground Dynamic range bias ++ (this will help fix the dark ground problem) Dynamic range limit +++++<br>\nВот все хорошо, но “+” это сколько? Может сообразит кто… <span class=\"emoji emoji-smiley\" data-nd-emoji-src=\":smiley:\">😃</span></p>\n","user":"50063c2a3df955007774201c","ts":"2012-11-07T06:31:51.000Z","st":1,"cache":{"comment_count":0},"views":678,"bookmarks":0,"votes":0},"subscription":null},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
