Квадрокоптер (build log) Квадрокоптер (build log) {"assets_hash":"a8b26fa7f6e768b07a72c8c9aadb9422","page_data":{"users":{"518d02c33df9550077736caf":{"_id":"518d02c33df9550077736caf","hid":152310,"name":"serebasha","nick":"serebasha","avatar_id":null,"css":""},"523584f03df9550077732224":{"_id":"523584f03df9550077732224","hid":174358,"name":"c3c","nick":"c3c","avatar_id":null,"css":""},"526d76f73df9550077730922":{"_id":"526d76f73df9550077730922","hid":180866,"name":"styxer","nick":"styxer","avatar_id":null,"css":""},"544eab273df95500777243ea":{"_id":"544eab273df95500777243ea","hid":210137,"name":"stvdedal","nick":"stvdedal","avatar_id":null,"css":""}},"settings":{"blogs_can_create":false,"blogs_mod_can_delete":false,"blogs_mod_can_hard_delete":false,"blogs_mod_can_add_infractions":false,"can_report_abuse":false,"can_vote":false,"can_see_ip":false,"blogs_edit_comments_max_time":30,"blogs_show_ignored":false,"blogs_reply_old_comment_threshold":30,"votes_add_max_time":168},"entry":{"_id":"545287209970730077110dd5","hid":19579,"title":"Квадрокоптер (build log)","html":"<ul>\n<li>Frame: Tarot FY650 IRON MAN 650 Quad-Copter Carbon Kit TL65B01</li>\n<li>Engines: T-motor MN3508 KV580</li>\n<li>Пропы: 14x4.7 карбон</li>\n<li>ESC: Tigermotor 30A (400Hz)</li>\n<li>Accumulator: Giant Power 4S 6500mAh</li>\n<li>Мозги: Naza М V 2+ GPS модуль</li>\n<li>Приемник: FrSky X8R</li>\n<li>провода</li>\n</ul>\n<p>Сборка</p>\n<!--cut-->\n<p>Wire harness - как замена PCB. Провод 12AWG от батареи разделяется на 5 проводников 14AWG к потребителям. Потребители это 4 ESC и PMU Naza. В будущем, когда дорасту до fpv и будет у меня подвес с камерой и передатчиком видео, сделаю еще одну развилку и воткну ее в пятый вывод<br>\n<a class=\"attach attach-img attach__m-sm\" href=\"https://rcopen.com/member210137/media/54526b899970730077666eac\" target=\"_blank\" data-nd-media-id=\"54526b899970730077666eac\" data-nd-image-orig=\"https://rcopen.com/member210137/media/54526b899970730077666eac\" data-nd-image-size=\"sm\"><img class=\"attach__image\" src=\"https://rcopen.com/files/54526b899970730077666eac_sm\" alt width=\"170\" height=\"150\"></a><br>\n<a class=\"attach attach-img attach__m-sm\" href=\"https://rcopen.com/member210137/media/54526b8999707300776668cc\" target=\"_blank\" data-nd-media-id=\"54526b8999707300776668cc\" data-nd-image-orig=\"https://rcopen.com/member210137/media/54526b8999707300776668cc\" data-nd-image-size=\"sm\"><img class=\"attach__image\" src=\"https://rcopen.com/files/54526b8999707300776668cc_sm\" alt width=\"170\" height=\"150\"></a><br>\n<a class=\"attach attach-img attach__m-sm\" href=\"https://rcopen.com/member210137/media/54526b8999707300776662d0\" target=\"_blank\" data-nd-media-id=\"54526b8999707300776662d0\" data-nd-image-orig=\"https://rcopen.com/member210137/media/54526b8999707300776662d0\" data-nd-image-size=\"sm\"><img class=\"attach__image\" src=\"https://rcopen.com/files/54526b8999707300776662d0_sm\" alt width=\"170\" height=\"150\"></a></p>\n<p>Wire harness в раме, прикидываю как подключить основные компоненты и как их расположить. Мест не так уж много, поначалу собирался некоторые устройства спрятать между нижней и верхней пластинами. Но все это пространство теперь занято проводами.<br>\n<a class=\"attach attach-img attach__m-sm\" href=\"https://rcopen.com/member210137/media/54527501997073007766748b\" target=\"_blank\" data-nd-media-id=\"54527501997073007766748b\" data-nd-image-orig=\"https://rcopen.com/member210137/media/54527501997073007766748b\" data-nd-image-size=\"sm\"><img class=\"attach__image\" src=\"https://rcopen.com/files/54527501997073007766748b_sm\" alt width=\"170\" height=\"150\"></a></p>\n<p>Пластинка из линейки для размещения mc naza.<br>\n<a class=\"attach attach-img attach__m-sm\" href=\"https://rcopen.com/member210137/media/545282229970730077667a6d\" target=\"_blank\" data-nd-media-id=\"545282229970730077667a6d\" data-nd-image-orig=\"https://rcopen.com/member210137/media/545282229970730077667a6d\" data-nd-image-size=\"sm\"><img class=\"attach__image\" src=\"https://rcopen.com/files/545282229970730077667a6d_sm\" alt width=\"170\" height=\"150\"></a><br>\n<span class=\"attach attach-img attach__m-broken attach__m-sm\" data-nd-media-id=\"000000000000000000000000\" data-nd-image-orig=\"https://rcopen.com/member1/media/000000000000000000000000\" data-nd-image-size=\"sm\"></span></p>\n<p>Площадка из двухстороннего скотча для приемника<br>\n<a class=\"attach attach-img attach__m-sm\" href=\"https://rcopen.com/member210137/media/5454ee919970730077669815\" target=\"_blank\" data-nd-media-id=\"5454ee919970730077669815\" data-nd-image-orig=\"https://rcopen.com/member210137/media/5454ee919970730077669815\" data-nd-image-size=\"sm\"><img class=\"attach__image\" src=\"https://rcopen.com/files/5454ee919970730077669815_sm\" alt width=\"170\" height=\"150\"></a><br>\n<a class=\"attach attach-img attach__m-sm\" href=\"https://rcopen.com/member210137/media/5454ed6b9970730077668c10\" target=\"_blank\" data-nd-media-id=\"5454ed6b9970730077668c10\" data-nd-image-orig=\"https://rcopen.com/member210137/media/5454ed6b9970730077668c10\" data-nd-image-size=\"sm\"><img class=\"attach__image\" src=\"https://rcopen.com/files/5454ed6b9970730077668c10_sm\" alt width=\"170\" height=\"150\"></a></p>\n<p>Наcтройка ESC<br>\n<a class=\"attach attach-img attach__m-sm\" href=\"https://rcopen.com/member210137/media/5454ecf69970730077668623\" target=\"_blank\" data-nd-media-id=\"5454ecf69970730077668623\" data-nd-image-orig=\"https://rcopen.com/member210137/media/5454ecf69970730077668623\" data-nd-image-size=\"sm\"><img class=\"attach__image\" src=\"https://rcopen.com/files/5454ecf69970730077668623_sm\" alt width=\"170\" height=\"150\"></a></p>\n<p>Красный провод от всех esc вынут из jst разъема, который в назу идет, и изолирован термоусадкой. Совсем его отрывать не стал, может пригодиться<br>\n<a class=\"attach attach-img attach__m-sm\" href=\"https://rcopen.com/member210137/media/5454eb40997073007766805c\" target=\"_blank\" data-nd-media-id=\"5454eb40997073007766805c\" data-nd-image-orig=\"https://rcopen.com/member210137/media/5454eb40997073007766805c\" data-nd-image-size=\"sm\"><img class=\"attach__image\" src=\"https://rcopen.com/files/5454eb40997073007766805c_sm\" alt width=\"170\" height=\"150\"></a></p>\n<p>Почти готово</p>\n<p><span class=\"attach attach-img attach__m-broken attach__m-sm\" data-nd-media-id=\"000000000000000000000000\" data-nd-image-orig=\"https://rcopen.com/member1/media/000000000000000000000000\" data-nd-image-size=\"sm\"></span></p>\n<p><span class=\"attach attach-img attach__m-broken attach__m-sm\" data-nd-media-id=\"000000000000000000000000\" data-nd-image-orig=\"https://rcopen.com/member1/media/000000000000000000000000\" data-nd-image-size=\"sm\"></span></p>\n<p><span class=\"attach attach-img attach__m-broken attach__m-sm\" data-nd-media-id=\"000000000000000000000000\" data-nd-image-orig=\"https://rcopen.com/member1/media/000000000000000000000000\" data-nd-image-size=\"sm\"></span></p>\n<p><a class=\"attach attach-img attach__m-sm\" href=\"https://rcopen.com/member210137/media/54526b8999707300776662d0\" target=\"_blank\" data-nd-media-id=\"54526b8999707300776662d0\" data-nd-image-orig=\"https://rcopen.com/member210137/media/54526b8999707300776662d0\" data-nd-image-size=\"sm\"><img class=\"attach__image\" src=\"https://rcopen.com/files/54526b8999707300776662d0_sm\" alt width=\"170\" height=\"150\"></a><a class=\"attach attach-img attach__m-sm\" href=\"https://rcopen.com/member210137/media/54526b8999707300776668cc\" target=\"_blank\" data-nd-media-id=\"54526b8999707300776668cc\" data-nd-image-orig=\"https://rcopen.com/member210137/media/54526b8999707300776668cc\" data-nd-image-size=\"sm\"><img class=\"attach__image\" src=\"https://rcopen.com/files/54526b8999707300776668cc_sm\" alt width=\"170\" height=\"150\"></a><a class=\"attach attach-img attach__m-sm\" href=\"https://rcopen.com/member210137/media/54526b899970730077666eac\" target=\"_blank\" data-nd-media-id=\"54526b899970730077666eac\" data-nd-image-orig=\"https://rcopen.com/member210137/media/54526b899970730077666eac\" data-nd-image-size=\"sm\"><img class=\"attach__image\" src=\"https://rcopen.com/files/54526b899970730077666eac_sm\" alt width=\"170\" height=\"150\"></a><a class=\"attach attach-img attach__m-sm\" href=\"https://rcopen.com/member210137/media/54527501997073007766748b\" target=\"_blank\" data-nd-media-id=\"54527501997073007766748b\" data-nd-image-orig=\"https://rcopen.com/member210137/media/54527501997073007766748b\" data-nd-image-size=\"sm\"><img class=\"attach__image\" src=\"https://rcopen.com/files/54527501997073007766748b_sm\" alt width=\"170\" height=\"150\"></a><a class=\"attach attach-img attach__m-sm\" href=\"https://rcopen.com/member210137/media/545282229970730077667a6d\" target=\"_blank\" data-nd-media-id=\"545282229970730077667a6d\" data-nd-image-orig=\"https://rcopen.com/member210137/media/545282229970730077667a6d\" data-nd-image-size=\"sm\"><img class=\"attach__image\" src=\"https://rcopen.com/files/545282229970730077667a6d_sm\" alt width=\"170\" height=\"150\"></a><a class=\"attach attach-img attach__m-sm\" href=\"https://rcopen.com/member210137/media/5454eb40997073007766805c\" target=\"_blank\" data-nd-media-id=\"5454eb40997073007766805c\" data-nd-image-orig=\"https://rcopen.com/member210137/media/5454eb40997073007766805c\" data-nd-image-size=\"sm\"><img class=\"attach__image\" src=\"https://rcopen.com/files/5454eb40997073007766805c_sm\" alt width=\"170\" height=\"150\"></a><a class=\"attach attach-img attach__m-sm\" href=\"https://rcopen.com/member210137/media/5454ecf69970730077668623\" target=\"_blank\" data-nd-media-id=\"5454ecf69970730077668623\" data-nd-image-orig=\"https://rcopen.com/member210137/media/5454ecf69970730077668623\" data-nd-image-size=\"sm\"><img class=\"attach__image\" src=\"https://rcopen.com/files/5454ecf69970730077668623_sm\" alt width=\"170\" height=\"150\"></a><a class=\"attach attach-img attach__m-sm\" href=\"https://rcopen.com/member210137/media/5454ed6b9970730077668c10\" target=\"_blank\" data-nd-media-id=\"5454ed6b9970730077668c10\" data-nd-image-orig=\"https://rcopen.com/member210137/media/5454ed6b9970730077668c10\" data-nd-image-size=\"sm\"><img class=\"attach__image\" src=\"https://rcopen.com/files/5454ed6b9970730077668c10_sm\" alt width=\"170\" height=\"150\"></a><a class=\"attach attach-img attach__m-sm\" href=\"https://rcopen.com/member210137/media/5454ed6b9970730077669221\" target=\"_blank\" data-nd-media-id=\"5454ed6b9970730077669221\" data-nd-image-orig=\"https://rcopen.com/member210137/media/5454ed6b9970730077669221\" data-nd-image-size=\"sm\"><img class=\"attach__image\" src=\"https://rcopen.com/files/5454ed6b9970730077669221_sm\" alt width=\"170\" height=\"150\"></a><a class=\"attach attach-img attach__m-sm\" href=\"https://rcopen.com/member210137/media/5454ee919970730077669815\" target=\"_blank\" data-nd-media-id=\"5454ee919970730077669815\" data-nd-image-orig=\"https://rcopen.com/member210137/media/5454ee919970730077669815\" data-nd-image-size=\"sm\"><img class=\"attach__image\" src=\"https://rcopen.com/files/5454ee919970730077669815_sm\" alt width=\"170\" height=\"150\"></a></p>\n","user":"544eab273df95500777243ea","ts":"2014-10-30T18:44:48.000Z","st":1,"cache":{"comment_count":4,"last_comment":"54608ef699707300771313d0","last_comment_hid":4,"last_ts":"2014-11-10T10:09:58.000Z","last_user":"518d02c33df9550077736caf"},"views":1499,"bookmarks":0,"votes":0},"subscription":null},"locale":"en-US","user_id":"000000000000000000000000","user_hid":0,"user_name":"","user_nick":"","user_avatar":null,"is_member":false,"settings":{"can_access_acp":false,"can_use_dialogs":false,"hide_heavy_content":false},"unread_dialogs":false,"footer":{"rules":{"to":"common.rules"},"contacts":{"to":"rco-nodeca.contacts"}},"navbar":{"tracker":{"to":"users.tracker","autoselect":false,"priority":10},"forum":{"to":"forum.index"},"blogs":{"to":"blogs.index"},"clubs":{"to":"clubs.index"},"market":{"to":"market.index.buy"}},"recaptcha":{"public_key":"6LcyTs0dAAAAADW_1wxPfl0IHuXxBG7vMSSX26Z4"},"layout":"common.layout"}
