GriffinRU's Blog
MambaMax Mods
13.01.2008 в 09:26 (4261 Показов)
MambaMax
All the mods started from this thread on RC-Monster Forum and temporary duplicated here.
Step by step Mod1:
ID:	399950Removing cover from ESC, by removing 2 screws. Fixing ESC in the wise for futher unsoldering.
Вложение 110923Unsolder side A
Вложение 110924 then side B
Вложение 110925 separate two boards
Вложение 110926 Remove stock capacitors
Вложение 110927 Clear capacitors vias for new components
Вложение 110928 Install new capacitors.
Вложение 110929 Add booster capacitor and zener diode (TVS).
Вложение 110930 Cut brass (copper) plate for internal FET's.
Вложение 110931 Apply thermogrease (i.e Arctic silver ceramique thermal compound) and thermoepoxy (i.e Arctic Silver Alumina Premium Thermal Adhesive) in the coners.
Вложение 110933 Re-attach Main heatsink with the same epoxy, if original was poorly secured.
Вложение 110936 Add small heatsink for CPU unit, just a copper foil/tape would be sufficient, securing with the same epoxy or tape adhesive. Check for airgap between CPU heatsink (and other components) and FET's heatsink (brass/copper plate).
Вложение 110934 Final view.
Step by step Mod2
Вложение 110921
Start with taking two ESC's apart.
Mass production always has problems with QC, check another heatsink problem...
Вложение 124571
New pcb layout with 6 layer, 6 oz copper helps allot but makes unsoldering challenging.
Вложение 124572
Grind FET's with sand paper (220+ Grid) on flat surface for better adhesion and flatness.
Вложение 125804
Apply Epoxy Top & Bottom
Вложение 125805Вложение 125806
Attach Top and Bottom heatsink plates.
Вложение 125807Вложение 125808
Solder header to the top board.
Вложение 125809
Solder new capacitors to the top board.
Вложение 125811
Check assembly.
Вложение 125812
Apply thermogrease for middle Fet's.
Вложение 125813
Solder middle layer capacitors and headers.
Вложение 125815
Reinstall CPU pcb.
Вложение 125816
Final view.
Вложение 125817
Will be continued...
Mod3 a and b (5S 150A 25-100C / 15S 75A 25-100C) New FET's, new Power board
Вложение 119594
Under development, resolving issues with layout and fet drivers.
Вложение 121490Вложение 121491
New Fet's and new layout from Castle Creations
Вложение 122498
MambaMax above 4S LiPo with LiPo support: DOESN'T WORK, DON'T TRY! UPDATE WILL FOLLOW.
