Pash_Ok
табличка для настройки камеры
graphics.cornell.edu/…/ISO_12233-reschart.pdf
Сервы
Модификация серв под 180 и др.
Пан тилт под 360 для камеры -19$
Сервы
Постройка клевера
www.rcgroups.com/forums/showthread.php?t=1388264
Каналы 1.2 RX|TX
Углы и мм камер
1.7mm lens has approximate 170 degree field of view
2.1mm lens has approximate 158 degree field of view
2.5mm lens has approximate 147 degree field of view
2.8mm lens has approximate 130 degree field of view
2.9mm lens has approximate 127 degree field of view (Natural Human eye)
3.6mm lens has approximate 92 degree field of view
4.3mm lens has approximate 88 degree field of view
6.0mm lens has approximate 78 degree field of view
8.0mm lens has approximate 58 degree field of view
12 mm lens has approximate 28 degree field of view
Про трекер
